Updated Search
1117
08-03-2022 04:06 PM
Status: Already Offered
TedCronin
We used Search to search for Waste as in Wastewater, We shouldn't see BusBar or Electric Anno, it should only find anything with Waste in it, like Wastewater.  Can we get the Search capabilty updated so it finds based on 'like' as a hidden parameter.  So if we tyoe Waste its like a FieldName LIKE Waste, rather than a FieldName IS Waste, which doesn't quite work either
2 Comments
Randy_Garcia
Hi Ted,
Our search looks through more than just the title to find items. You can use the following tools to narrow down the search in ArcGIS for AutoCAD as these should work as they do in AGOL.
https://doc.arcgis.com/en/arcgis-online/reference/advanced-search.htm
for instance appending "name:" in front of your search term should limit the search to name.
TedCronin
We are finding that the search just doesn't quite work as we would hope, its completely broken.  If I try and query a Map Service, My expectation is all the Feature Services would disappear because they are not map services.  We have been trying and failing so far to get anything to work for Search, we wind up favoriting layers or manually scrolling both not ideal in a production env when you have hundreds of layers.
