Support defining labels from multiple attributes
483
03-09-2025 02:40 PM
Status: Open
Marc_Graham
Please support using multiple attributes for labels with newline and concatenation capabilities similar to ArcGIS Pro.
Marc
3 Comments
MichaelDavidsonPM
Hi @Marc_Graham,
Thanks for posting this Idea.
For this item, have you considered a LISP approach? For example, you might consider using LISP to select multiple attribute values and then create/relatively position a label for each selection.
For considering a LISP approach here, before incorporating commands, please note that those such as Esri_PickLabel create links between the attributes and the TEXT/MTEXT entities. See additional details here: https://doc.arcgis.com/en/arcgis-for-autocad/latest/manage/feature-linked-labels.htm
Marc_Graham
Hi @MichaelDavidsonPM
Ideally we are after a straight forward approach to making slightly more sophisticated labels that is easy for the end user.
Two common use cases:
  • Road labels where the road name and the road type are stored in separate attributes
  • Property titles where the Parcel ID and Title description are stored in different attributes
Marc
MichaelDavidsonPM
Hi @Marc_Graham,
While we're not planning in the near or medium term to add a user experience for this functionality, we are considering adding a LISP sample to our repository that will allow for newline and concatenation behaviors.
