Read from Branch Version
1805
03-02-2022 01:03 PM
Status: Implemented
JimmyBowden
I would like to be able to connect to a service with branch versioning enabled.  Then get a list of available versions and set that version so that all subsequent operations are completed use data from that version.  Specifically I would need read access as there is no current requirement for edit access.
3 Comments
Randy_Garcia
Branch Versioning is an important functionality. Thanks for the detailed description of how you plan to use it.
Randy_Garcia
MichaelDavidsonPM
Hi @JimmyBowden,
The ArcGIS for AutoCAD team implemented branch versioning as part of the version 430 release. Here is a blog post that gives an overview.
You can now add branch version enabled web feature layers to your drawings. You can also create and/or change to named branch versions for layers of interest. Read/edit access is determined in accordance with your Esri named user account and level of access to a given web feature layer. Additional technical details are here.
Thanks again for posting this idea and for providing details of your planned usage of branch versioning.
