I am noticing that the privileges for working in Field Maps are limited depending on whether you own the layer and/or the map and it poses difficulty for projects involving collaboration across teams/people.
For example, if you own the layer but not the map, you can't edit the form configuration in Field Maps Designer. You also then can't save the configuration to the layer. If you own the map and not the layer, you are not able to change default and templates within Field Maps Designer for that layer.
Before I submit an idea/enhancement I am wondering if this is a limitation to Field Maps or something I am just not aware of. Anyone else experience a similar issue, or have a workaround for this?
