Version Management in ArcGIS Field Map.
516
03-13-2026 12:33 AM
Davis_Dad23
Hello,
I wanted to ask for the support about the version management in ArcGIS Field Map.
Is it possible to work with Named version on an online ArcGIS Field Map and be able to submit collected data to the Named Version instead of the default Version.
I know it works on offline Field map but i want to understand on the part when we are working on online if we can have same capabilities to do it.
JeffShaner
Hi @Davis_Dad23 ,
If you are referring to branch versioning, yes you can. Inside of the Versioning section of App Settings within Field Maps Designer, you can choose a specific branch version to switch to for each feature service in your map. This post from @TravisSaladino highlights the experience added with ArcGIS Enterprise 11.5.
We are planning to support defining a list of versions per feature service that the mobile worker will be able to switch between. With Field Maps Designer, this will be included in the 12.1 release of ArcGIS Enterprise and a future update of the mobile apps later this year will provide the ability to switch between that subset of versions.
Davis_Dad23
Thank you for the update information @JeffShaner , Does it also mean that we don't have this functionality of Versioning Section in Field map in ArcGIS Enterprise 11.4?
