Using smart forms in Pro?
2401
05-17-2021 03:51 PM
DougBrowning
MVP Esteemed Contributor
I like that you can add using the form in Field Maps or the Web Map and it looks similar.  I thought these also worked in Pro but I cannot get it to go.
Is this coming later?  If now how?
thanks
DougMorgenthaler
@DougBrowning support for forms is currently not available in ArcGIS Pro. While the team is monitoring this, I'd recommend adding an idea to ArcGIS Pro.
DougMorgenthaler
SimonSchütte_ct
MVP Regular Contributor
