Update Map Configuration for Offline Map Area Without Deleting on Device
561
12-14-2022 06:14 AM
by Anonymous User
Not applicable
I have a map in Field Maps where I have created an offline area in the web app. I have the updates set to daily. I have downloaded the map area within the Field Maps app on an iPad. I've noticed that if I make a change to the popup of one of the layers or if I make a change to a question in the Field Map web editor, the change is not does not show up in the downloaded map area on the device. The only way I've found to get the configuration changes to show up is to delete the offline area from the device and download it again. Is there a way to get the changes to the popup or question configuration to show up in the downloaded map area without having to delete and re-download the offline area?
