Triggering Calculated Value expressions
704
04-07-2026 01:34 PM
Pukawai
I have added a field to a hosted feature layer and created an Arcade expression to calculate it's value,
The expression works fine if I do any kind of edit in FieldMaps, but only for the edited feature.
Is there a way to trigger the execution of this expression for all features?
TL2
Other than field calculation, NO, they're called attribute rules and they are only for enterprise.  We all want this feature badly.
TL2
Pukawai
Thank you. I'll stop looking for something that doesn't exist and write some python to do a bunch of selects and field calcs...
RhettZufelt
MVP Notable Contributor
Sure you can.
Just go to the Item Details page, Data tab and you can do it there.
R_
Pukawai
No, that calculates a field based on some expression you have to build, not the one that is in the layer's form.
