Track Viewer // Location sharing icons
900
09-02-2024 07:57 PM
elpinguino
Hi Field Mappers,
I really like in Track Viewer how we see the ArcGIS Online profile photos of each individual as the Last Known Location icon. When I add the layer into a Map Viewer or Field Maps or look at it in the hosted feature service visualisation tab the Last Known Location reverts back to the user's initials.
Is there a way to have this capability flow through outside of Track Viewer? Maybe it already does, and I missed  a step? Or is it not possible, and I'd need to load the images into ArcGIS Online and put each one as a symbol and save as the layer to use across the different maps in the project?
Thanks in advance for your reply.
JakeBrownMaps
Hello @elpinguino, the last known location layer symbology created by the Track Viewer app is using a symbol type that isn't currently supported in Map SDK / Runtime (we do have an enhancement request in to support it).  You can however change the layer symbology / labeling.   Using a little bit of Arcade you can create initial labels that will show in Field Maps:
return Split($feature.full_name,' ')[0][0] + Split($feature.full_name,' ')[1][0]
Here is a link that steps through configuring labels.
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-labels-mv.htm
I would recommend the center - center placement for the text then create a filled marker symbol underneath the label.
Hope that helps -
Jake Brown
Field Maps Product Engineer
elpinguino
Thanks for the reply @JakeBrownMaps. I will give the initials a go for now. Looking forward to seeing the profile pics one day.
