Sync Failed Error: Unable to synchronize replica. Sync replica Internal error.
9632
11
05-08-2024 08:02 AM
JustinH
Hi Everyone-
I continue to have an annoying Sync error in my field maps. It seems like this was an error in Collector, but I am unable to find a solution to get rid of this sync error.
In offline mode, every time I hit sync, I get the error "Unable to synchronize replica. Sync replica internal error." But the edits that are made still push to the source.
So, there is no issue with what field users need, but it happens to tell the field user that everything is failing... I would love to eliminate this error so users have a smoother UX.
Thanks for the help in advance.
ClayDonaldsonSWCA
many potential causes of this error. I would recommend turning on troubleshooting logging, then attempting to sync and reviewing the logs.
It's likely a single layer causing the error message to be thrown. Search 'error' in the logs and you can help determine which is the troublemaker.
JustinH
Thank you for the reply. This is helpful. I have identified the layer pushing this error but I am not sure how to fix it.
JustinH
I am not sure this was the solution... but it was. I found the layer that was causing the issue. All I did was make sure edits and track changes were enabled. Originally I had only the sync function enabled. IT took forever to save, so I deleted the feature and republished it from the online zip file. I just synced and no errors. I am not sure this really gave me the solution I was looking for but I did resolve the issue! and now I know a little more about troubleshooting on the backend.
Thanks!!!
KerriRasmussen
Hi @JustinH . I'm sorry to hear that you are having an issue with ArcGIS Field Maps. When you are syncing the data, are you syncing from the device > portal (either ArcGIS Online or ArcGIS Enterprise) or portal > device, or both? Since you created the offline area(s) have you made any schema changes or any other changes to your map/data?
JustinH
Hi Kerri-
Thank you for your reply. I am currently syncing from the device to the portal. I have pushed changes but make sure to redownload a new area every time I push those changes.
RhettZufelt
MVP Notable Contributor
When you 'pushed' changes, did you re-create the Offline areas, or just Update them?
R_
JustinH
This is something I have not tried, I actually did not even know about this. We usually have the user create their own offline area.
JoshuaKeeley_NHDES
Hi Kerri, I'm seeking help on this subject as well. I am the creator of an editable web map in Field Maps. I updated it with new layers, made sure it was editable and offline-enabled, then shared it with others in my organization and asked them to download a new offline area. One staff member may not have downloaded the newly updated map from AGOL, so his will no longer sync due to a replica error. To help me understand how to fix this and save his edits/data, it would help greatly if you could please look at the attached image and answer this one question first: The blue header in the pane behind the error message (circled in red) reads "Sync Now - Aug 23, 2024". Can you tell if that refers to the date that the offline map was downloaded locally, or the date when the staff member last synchronized the data? Many thanks in advance!
KerriRasmussen
@JoshuaKeeley_NHDES The date that you have circled is the date that the map was last synchronized. If the user has data on their device and you are unable to sync, you may want to check out this article for some assistance. https://support.esri.com/en-us/knowledge-base/how-to-access-offline-edits-from-arcgis-field-maps-dir...
