Hi Everyone,
Looking to start and stop 'My Tracks' functionality in Field Maps from inside a Survey123 form. The form is used for tracking Wildlife Field Inspections.
Anyone already figured this out and can give me some pointers? It would be greatly appreciated!
Marjorie
Solved! Go to Solution.
Hi Marjorie,
I havent tried from within Survey123 but it should work the same as accessing the link from elsewhere. The link should look like this:
https://fieldmaps.arcgis.app/?referenceContext=track&trackingOn=true
This link would open Field Maps and toggle on Location Sharing. Additional details can be found in the doc here. You can optionally set a Location Sharing duration outside of the default options.
Regards,
Colin
Hi Marjorie,
Regards,
Colin
Thanks Colin!
Up and running. I appreciate the assistance!
Marjorie
