Special characters in layer name prevent layers from loading
5544
11
05-04-2023 06:44 AM
StefanUseldinger
Today, we upgraded from ArcGIS Enterprise 11.0 to 11.1 and receive the following error on our iOS devices:
04.05.23 10:56 Layer (LAYERNAME) failed to load with error: Error Domain=com.esri.arcgis.runtime.error Code=2 "Invalid argument." UserInfo={NSLocalizedFailureReason=UTF8 contains invalid characters, NSLocalizedDescription=Invalid argument., Additional Message=UTF8 contains invalid characters}
I found out, that the initial loading of the map worked without issue. However, after subsequent reloading of the map and restarting the app, some layers could not be fetched.
I narrowed down the issue to Hosted Feature Services. Regular FS and Map Services were not concerned afaik. I noticed that only Hosted Feature Service layers are facing the issue, where the layer name contains special characters. By this, I mean the layer name exposed on the Rest interface. You can also rename the non-special-character layer with special characters in the map config (“override”), but this does not produce the error. The Hosted Feature Service may also contain special characters; Field Maps can handle it well.
After renaming the service layer in the Admin Rest API the problem does not occur anymore.
Is this a known behavior?
IvanPobis1
I have same problem after upgrading ArcGIS Enterprise from 11.0 to 11.1.  Quick Capture Works fine.
StefanUseldinger
The recently released ArcGIS Server Patch fixes both issues (special characters in domain values and layer  names for hosted and non-hosted feature services).
  • BUG-000158047 - When making multiple requests to a map service with returnAdvancedSymbols=true, non-ascii characters are incorrectly encoded in responses after the initial request.
  • BUG-000158045 - Feature service layer resources with returnAdvancedSymbols=true&returnDomainNames=true can have inconsistent responses.
  • BUG-000158036 - Non-English characters are not displayed properly in custom data feed feature service responses.
  • BUG-000154221 - After installing the ArcGIS Server Security 2022 Update 1 or 2 Patch, the KML region URL of a map service is invalid.
