Search in Field Maps using Android device returns 0 results
784
05-03-2021 09:43 PM
ChrisFlaherty
Hi Community,
I am having an issue with the search option in Field Maps (and Collector) when trying to use this option on an Android device. No matter what the content of the search, it always returns 0 results, even if the search involves an asset I am 100% sure is there. The search works perfectly when tested on an iOS device using the same map.
Has anyone else experienced this problem on an Android device? If so, how did you fix the issue?
Many thanks.
ColinLawrence
Hi @ChrisFlaherty ,
Are you still having issues with this? Do you see this issue in other maps? You could try removing and re-adding the feature search settings from the Web Map and saving again.
Regards,
Colin
Regards,
Colin
