Returning UTM coordinates (zone 11) in displayed in popup & as auto-populated attributes in new field-collected, content
2239
03-10-2022 11:52 AM
amyw
I am trying to meet a request for field staff to collect information in field maps, and have UTM coordinates supplied on-the-fly  as pop-up attributes and ideally populate the attributes of points collected in the field.  Is there a way to do this?  Does it require publishing the data in UTM zone 11 projection?  I am open to using map viewer classic or trying map viewer.  In the past, I had made a web map in classic map viewer to share with field workers in a remote environment with offline maps.
AJ_devaccount
Hi @amyw, did you end up figuring out how to calculate UTM coordinates?
Larry
Have a look at the reply I sent to question: Autopopulate UTM (NAD83) coordinates
It should work for you as well.
https://community.esri.com/t5/arcgis-field-maps-questions/autopopulate-utm-nad83-coordinates/m-p/118...
