Restricting a radio button/switch based on proximity to a map point
786
04-16-2024 02:58 PM
WILERMJOSEPERAZAPIMENTEL
Hi everyone,
I hope this finds you well.
I'm working on a Fieldmaps project where I need to restrict the visibility of a radio button or switch based on the user's proximity to a selected point on the map. I want the form to only be active if the user is within 50 meters of the selected point.
I've searched the documentation and forums, but I haven't been able to find a solution for this specific scenario. I've tried using expressions and triggers, but I haven't been able to get it to work as expected.
Any suggestions or guidance would be greatly appreciated.
This is my calculated field in Arcade
Arcade code:
// Verificar si el radio button es 'Visitado'
if ($feature.Llegada_al_Cliente == 'Visitado' && IsEmpty($feature.HoraIni) ) {
    // Asignar la hora actual a una variable
    var currentDateTime = Now();
    // Asignar la hora actual al campo 'HoraIni'
    return currentDateTime;
} else {
    // Si no es 'Visitado', mantener el valor actual del campo 'HoraIni'
    return $feature.HoraIni;
This is my idea, but it gives me an error.
// Verificar si el radio button es 'Visitado' y si la distancia al punto es menor a 50 metros
if ($feature.Llegada_al_Cliente == 'Visitado' && Distance($feature.location, $geometry) < 50) {
} else {
// Si no es 'Visitado' o la distancia es mayor a 50 metros, mantener el valor actual del campo 'HoraIni'
error:
Invalid property identifier, expecting ObjectId
error: $feature.location
