Record time in field maps
385
10-31-2024 05:09 AM
DianaAlvarez
I need a field to record time in format 10:23, we are using field maps. what type of field do I need to use and how do I set it up when it is already shared to portal enterprise?
ChristopherCounsell
MVP Regular Contributor
Two options:
  • DateTime field + record both date and time
  • String field, record the time as a string.
If calculating it use Arcade:
  • Now() will calculate the current date and time for a datetime field.
  • Text(Now(), 'h:m') will take the current date and time and format it as text for hours and minutes only.
https://developers.arcgis.com/arcade/function-reference/text_functions/#text
More Text conversion with time examples above.
Arcade functions for DateOnly and TimeOnly, and the Date and Time only field types, won't be supported in Field Maps yet, so don't pursue those.
