Raster file with unique valued value symbology/file geodatabase rasters?
797
05-19-2021 10:07 AM
JacksonPatrick
I was hoping to add a file geodatabase raster to field maps, but whenever I create a MMPK of the raster it wont display in Field Maps.
I then tried using other raster formats which Field maps will display, but they lose their symbology when in Field Maps which defaults the rasters to stretch symbology
I also tried creating a vector file from the raster, which does work in Field Maps, however it is massive and not reasonable to create a MMPK from at the scale I need.
Any advice on how to get a raster with unique valued symbology to work in Field Maps?
bshamg01
Hi Jackson,
I am also having this same issue with lost symbology of a raster when I bring my .mmpk file into Field Maps. Did you ever find a solution?
Ben
