I'm running Field Maps version 22.1.1 Build 1114 on an Samsung Galaxy Tab Active 3, Android Version 11. I am seeing an issue where one of my map layers fails to load. This is a feature layer that was generated by Survey123 Connect 3.14.274 and has coded domain values. Oddly, it has loaded a few times today but when I closed and reopened Field Maps it did not load.
If I click the share error option, I see this:
"Map Layer Failed to Load
Map: <map name>
Layer: <layer name>
Domain: ARCGIS_RUNTIME
Code: 3079
Description:
Domain Exists.
If I load the same map on an iPad and iPhone it works fine.
Any suggestions on how I can troubleshoot and solve this? Our fields crews all have the same Samsung tablet, so I'm hoping to resolve this soon!
