"Map Layer Failed to Load" Domain Exists. Domain: ArcGIS_RUNTIME Code 3079
2020
04-22-2022 03:43 PM
Strahanjen
I'm running Field Maps version 22.1.1 Build 1114 on an Samsung Galaxy Tab Active 3, Android Version 11. I am seeing an issue where one of my map layers fails to load. This is a feature layer that was generated by Survey123 Connect 3.14.274 and has coded domain values. Oddly, it has loaded a few times today but when I closed and reopened Field Maps it did not load.
If I click the share error option, I see this:
Map: <map name>
Layer: <layer name>
Domain: ARCGIS_RUNTIME
Code: 3079
Description:
Domain Exists.
If I load the same map on an iPad and iPhone it works fine.
Any suggestions on how I can troubleshoot and solve this?  Our fields crews all have the same Samsung tablet, so I'm hoping to resolve this soon!
by Anonymous User
Not applicable
It's a bit odd that you don't consistently see this issue. Usually this error is caused by there being multiple domains within a feature service or within the same layer that have the same domain. See this support article for more details.So it may be possible that your survey has been published incorrectly.
Strahanjen
Thanks for your thoughts. I copied and pasted my survey configuration into a brand new template and republished it. I'm no longer seeing the issue.
