I am moving our field teams off of Workforce with the creation of the new Field Maps Tasks.
I am curious to know if there is anyway to enable push notifications when a user is assigned a task. If the esritask_assignee field is set to a username, I would want them to get a push notification on their device. I know we could set up an email with Make/Power Automate, but I am specifically hoping for a push notification.
If not, is this functionality possible to set up? Is it something that will be developed for future releases of Field Maps?
To get task notifications, you’ll need to allow system notifications the first time you open a map with tasks. If you say no, you won’t get alerts — but the task list will still update in the app. If you allow them, notifications will start working after you relaunch Field Maps.
Note: You won’t get notifications for tasks you assign to yourself.
Just chiming in to say I desperately need this functionality. "In app" notifications and triggering an e-mail through power automate are not effective options for me. I have projects that want to generate hundreds of tasks over the project lifecycle and none of that needs to happen via e-mail. I need my field staff to get a push notification when something is assigned to them. I am soooo disappointed this wasn't minimum viable product functionality for Tasks.
Mike, it appears it was! See Laura's comment. I was able to implement with no problem.
How did you implement this? I am not seeing an option to allow notifications when the map is opened.
It should've asked the first time you opened the map.
Are you getting notifications to your home screen or just in app?
It's been a while since I set this up but I want to say it came across the regular notification bar in my phone, same as a text would. You could always reach out to the team if you originally clicked no or are not seeing notifications.
I am testing it out on their iPads right now and I'm unable to get a notification outside of the app after allowing notifications.
Wonder if it could be different between a phone and a tablet but I don't really know. I can try some testing.
French but looks like they are getting notifications: esri
I would appreciate that. Thank you
