Problems packaging offline areas through field maps designer.
1731
09-27-2023 08:24 PM
PeteloMaosi
Our program works in remote areas, so it is vital to have offline areas to work with. Maps are usually loaded with several layers that receive updates regularly. Old data is removed and from these maps. Everything is double checked through the field maps designer app.
Recently however, we have not been able to get past the packaging stage of the creating the offline areas. I have even removed all the layers from maps and tried creating offline areas. None seem to package. This was a common practice in our workplace a month ago and what seems like overnight does not work no matter what we do.
EddyClark
Could be the size limitation I just found out about.  Is this a large area?  Please see my "idea".
PeteloMaosi
Didn't know that was a thing but when I was trouble shooting I was taking a couple meters by couple meters square and it was still having a hard time. We had an easier time packaging after switching from an esri base map to a program made on.
