Please help with batch exporting photo attachments in Field Maps
1770
09-04-2022 05:27 PM
SamRycken
I would like to batch export my photo attachments from Field Maps on my local network. I need an efficient way to have multiples photos that are associated with a single survey be named in a way that lets me know what survey they're tied to. I have discovered a couple of scripts for ArcGIS Collector that batch export the attachments to my local folder, but the script only address one attachment per survey. I believe this happens because the script is written in a way that it assumes the attachment table is a one-to-one with the feature layer. I typically have a couple of photos per record and my surveys entail hundreds of records. I am able to get the first attachment exported with appropriate names but the script ignores a second or a third attachment for the same record. Would anyone be able to help me with a complete script that exports all photo attachments for each record?
This is the script that I have been using:
# imports the necessary modules to run
from arcpy import da
import os
attachTable = arcpy.GetParameterAsText(0) # table in GDB holding attachments
origTable = arcpy.GetParameterAsText(1) # layer in GDB holding features to which attachments belong
nameField = arcpy.GetParameterAsText(2) # field in origTable that contains more appropriate name for attachment
fileLocation = arcpy.GetParameterAsText(3) # folder where you want to save the photos
# create the cursor to search through the attachment tables; specify you only wish to search those three fields
attachCursor = da.SearchCursor(attachTable,['DATA','ATT_NAME','REL_GLOBALID'])
# begin searching the table and storing the actual images, movies, etc
for attRow in attachCursor:
binaryRep = attRow[0]
fileName = attRow[1]
relID = attRow[2] # defines the relationship ID that we can use to join to the actual features (origTable)
# creates a cursor to sort the features; essentially to find a match for the relID above
originCursor = da.SearchCursor(origTable,['GlobalID', nameField])
for origRow in originCursor:
origID = origRow[0] # store the Global ID (which will match to the relID above for the correct attachment)
origName = origRow[1] # store the unique name of each record that you will use to save the attachment
if origID == relID: # stops the search after it finds the record which equals the ID from the attachments
break
# saves a file in the specified location that contains the name chosen by the user for that attachment
open(fileLocation + os.sep + origName + ".jpg",'wb').write(binaryRep.tobytes())
# iteratively deletes the searchCursor from the feature class so it can reboot for the next attachment!
del originCursor
# If you are creating script from Sratch in ArcGIS
# Parameter(0) Type = Table
# Parameter(1) Type = Feature Layer
# Parameter(2) Type = Field (obtained from Parameter(1)
# Parameter(3) Type = Folder (make sure it is an input)
DougBrowning
MVP Esteemed Contributor
Looks like your code keeps naming all the photos the same name this will overwrite it each time so you just get 1.  In 123 I have a field that calcs my photo name for me then I use that.  You could add a field with Arcade to do that or you could just have the script query the output dir and get the number of files then add 1 and append that to you export name.  (assuming not other stuff in the folder)
Something like (I did not check syntax but you get the idea).
numberToUse = count(os.listdir(fileLocation)) + 1
open(fileLocation + os.sep + origName + str(numberToUse) + ".jpg",'wb').write(binaryRep.tobytes())
Hope that helps
My script is here  https://community.esri.com/t5/arcgis-survey123-questions/match-survey123-photo-attachments-to-featur...
I then create HTML pages in the dir with this https://community.esri.com/t5/arcgis-survey123-questions/best-practices-for-survey123-photo-storage/...
