Pass GlobalID from a polygon feature to a point feature
531
06-16-2023 04:13 AM
ALBJORGUI
I have a doubt about a potential workflow that I need to create.
I have a polygon feature layer that I create using field maps. This polygon will capture the geometry, globalID and some other field.
Once the geometry is saved, I would like to create a point that should inherit the globalID from the polygon(guid) and have its own globalID and some other attributes as well.
The question is, how do I make that relationship work to obtain the globalID from the polygon if I can only create the point after the polygon has been created and saved?
Albert
