Offline map areas - admin vs. mobile worker
1170
06-20-2024 11:32 AM
GeorgNussbaumer
Hi there,
I have an offline map area created in Field Maps Designer. I am able to download the offline map area as the administrator. The map area is shared with my organization and a group which consists of all of our mobile worker licenses.
When I am logged in as a Mobile Worker User, the offline map area does not download. The download completes and then nothing happens. Has anyone encountered similar issues? Any work around solutions?
I have enabled the map for offline use. I have recreated the offline area. I have updated the offline area. Creating the offline area in Field Maps causes the download to 'Fail'.
Any ideas?
Regards,
Georg
DanielFox1
Hi @GeorgNussbaumer
Have you had a look into the log files on the device?
Have a look at this documentation on how to extract the log file from your device which might point you in the right direction
https://community.esri.com/t5/arcgis-field-maps-blog/how-to-export-your-troubleshooting-log-file-fro...
Is there content that is still owned by the owner and shared in correctly?
Could be one to raise with your local distributor
