Offline areas not working with contingent values
891
09-05-2023 08:10 AM
cmoore_ne
I am getting an error when trying to create offline areas for a map that contains a hosted feature layer with contingent values. Error message in field maps shows as "Error 500. Unable to create replica. Please check your parameters.", while attempting to create an offline area in the field maps webapp also fails.
The contingent values in the feature layer work fine in "online" mode in field maps. I have tested an identical map with an equivalent layer without contingent values and that is downloading offline areas with no issues. I have noticed a previous threads on here relating to sharing settings, but that is not the issue here as the layer & map are shared to the same group, & I am the owner of the layer, map & group it is shared to.
Please help!
