Offline Area Download in Field Maps Requires ArcGIS Online Login
555
05-12-2025 05:27 AM
JohnGoat
We are using ArcGIS Enterprise 11.3 and have published a feature service from our enterprise geodatabase. Based on this, we created a web map configured for offline use in ArcGIS Field Maps, following the steps shown in this official video:
▶️Creating an Offline Area in ArcGIS Field Maps - YouTube
All settings related to offline areas and sync have been correctly configured. However, when trying to download an offline area within the Field Maps mobile app, a login screen for ArcGIS Online appears, requesting AGOL credentials.
  • The problem is:
    We only use ArcGIS Enterprise — we do not have an ArcGIS Online account.
  • Our basemap seems to trigger this behavior, even though everything else is hosted on Enterprise.
We would like to understand:
  • Is this behavior expected?
  • Is the issue caused by the default basemap referencing ArcGIS Online?
  • How can we publish and use web maps for offline workflows without requiring ArcGIS Online login, when using Enterprise-only infrastructure?
Any guidance or best practices would be greatly appreciated.
PS: I do these operations with the creator user.
sjones_esriau
Yes this is the expected behavior because the basemap references ArcGIS Online.
You can however take the basemap offline in Enterprise either manually via a web map or via a script.
https://enterprise.arcgis.com/en/portal/latest/use/take-maps-offline.htm#ESRI_SECTION2_384E9B7E99EC4...
https://mediaspace.esri.com/media/t/1_4wpkj48u
JohnGoat
@sjones_esriau thank you for answer.
"Use an Esri basemap offline
You can take an Esri basemap from ArcGIS Online offline with an ArcGIS Enterprise web map. To do so, you must have an account as a member of an organization in ArcGIS Online, and your environment must have access to the internet."
We do not have an Arcgis Online membership, does that mean we cannot use it without a arcgis online membership?
