Name trace query failed error in ArcGIS Field maps
871
05-17-2024 12:24 AM
April_J
Hello,
After I had posted about trace utility network not working in ArcGIS Field Maps (Can't trace a utility network in ArcGIS Field Maps), I found that the troubleshooting log had an error about the utility network. The error is [Utility Network] - Name trace query failed: com.esri.arcgisruntime.ArcGISRuntimeException: Unlicensed extension.: Utility network tracing requires a Utility network extension licenseI already use an account that has ArcGIS Utility Network License in ArcGIS Field Maps. I also log in to the rest service on the mobile but it's still not working.
Has anyone ever found this problem and how do you solve it?
How can I enable a Utility Network license in ArcGIS Field Maps?
