Looking for recommendations on Field Tablet
10813
10
08-17-2023 08:53 PM
JenniferMichaud
I'm looking for recommendations on an afordable field data collection tablet. I'd like something Android based that is rugged and can be used with Field Maps and some other Android-based applications.
DougBrowning
There really only is one - the Samsung Active 4 Pro.  Rugged, has dual band GPS so does submeter, swappable batteries, etc.  The rest tend to be higher end.
JenniferMichaud
Hi Doug, thanks. Would this be a good option? Not seeing that the Active 4 Pro is readily available. I'd like it to work with Verizon carrier. Its so confusing what to buy.
https://www.amazon.com/Enterprise-UNLOCKED-Biometric-Security-SM-T577UZKGN14/dp/B08T7TZK8B/ref=cm_cr...
Y_Chau
You should buy what is locally available in your area with good support. If not then go for the Chinese tablets with Ublox Z-F9P GNSS. Pick any like Stonex, CHCNAV...just make sure the GNSS is the 184 channel Ublox Z-F9P. Excellent performance with CORS and works great with Field Maps. Without CORS can get you below 1m.
Samsung Tab Active4 Pro is good if you don't need cm positioning. Handheld Group of Sweden also make good rugged tablets.
dsinha
Looking to buy android field tablets for my organization. Has anybody tried the Galaxy Tab Active5 or should I stick with Active 4 Pro?
Deb.
Y_Chau
IMO 8 inch is good if you want to pair with a pole mounted antenna. 10 inch is too big for that. If you will use the tab solo then both are fine. But 10 inch still feels big and heavy while out in the field. So Tab Active5. It should also have some performance enhancement.
BrianNorman
Hi @dsinha, did you ever manage to evaluate between the Galaxy Tab Active5 and Active 4 Pro? I appreciate there's a screen size difference, just wondering if you went for one of these options as we are currently looking to upgrade.
dsinha
Hi @BrianNorman,
We haven't bought anything yet but most probably will go with Active4 Pro. The specs of Active5 is a bit underwhelming.
BrianNorman
Yes, I agree, this is the conclusion I have come to. Thanks for replying.
