Limit on Contingent Values
1821
08-23-2023 10:29 PM
NathanHeickLACSD
It looks like contingent values are supported in ArcGIS Online and Field Maps.  If so, what is the maximum number of contingent values you can load onto a layer?  For example, can you create 60,000 contingent value entries?
AlexanderGray
Honored Contributor
I have the same question for ArcGIS pro.  I am looking the restrict values based on selection and 5 fields in one group and the number of valid combination is a factorial so ends up being a couple thousand and have 2 field groups.  I wonder if that has been tried or if I need to do the logic in UI code.
Tags (1)
rboreux
Hello,
I added 26 000 contingent values and the performance is not acceptable.
I hope I can improve it.
Kind regards,
Simon
ShaneONeill_144
For Android devices, there is a bug which may explain poor performance with large amounts of contingent values
BUG-000158487: There is a performance issue when loading a long list of contingent values in ArcGIS Field Maps on Android.
