Limit collection to just one choice for Unique Symbology layer
517
02-20-2025 09:57 AM
Clubdebambos
MVP Regular Contributor
Hi all,
I have a layer that uses two fields for symbology and there are four possible unique combinations. In Field Maps all four appear when I select Collect Here.
Is there any way to limit the collection to just one of the choices?
For example, I only want to be able to collect for New Pole (Not Complete) as per the below. There should not be an option for the other three when collecting new records.
Cheers,
Glen
~ learn.finaldraftmapping.com
Clubdebambos
I figured this out.
Before publishing from ArcGIS Pro, go to the Edit tab, in the Features group, click the Manage Templates arrow to the bottom right of the group.
The Manage Templates pane will open. Select the layer of interest in the templates and remove/delete any option you do not want collected.
When using Field Maps only the one option I want is available for collection.
Clubdebambos
I figured this out.
