Issues packaging areas for offline map
4779
05-10-2021 06:10 PM
Strahanjen
I've been struggling most of the day to create areas for offline use. I wonder if someone can help me figure out how I can get offline areas working. Here are the steps I followed:
1. I created two different views of a hosted feature layer with different filters for each
2. I made sure that Sync is enabled for both layers.
3. I added both layers to a new web map.
4. I went to the settings of the web map and enabled offline mode
5. I opened the Manage Areas section and added a new area. To test, I drew a rectangle that was less than 1 square mile and specified zoom levels from state to cities. Packaging has been running for over an hour now.
Earlier I tried with the hosted layer instead of the layer view and got packaging failed messages.
Can someone tell me where to find error messages so that I can determine why packaging failed?  Any other tips?
kjohnfs
I had this same issue. The feature layer I uploaded had an identical name to a previously deleted file, and was taking hours to package before failing.
Esri wasn't able to figure out the problem but I think my layer was corrupted from file name overlapping. When I reuploaded the same file with a different name it worked fine.
Hope this helps!
by Anonymous User
Not applicable
Just a guess, perhaps hosted layer views are not yet supported?
Also, in Chrome hit F12 to open the developer tools and look for an error message when the packages fails.
Strahanjen
Thanks for the tip to check developer tools for the error message when the package fails. I hadn't thought of the error showing up there!
kjohnfs
Hope this helps!
Strahanjen
Interesting, this might have been my issue. Oddly, late last night it just starting working again, though I'm not sure if that has to do with the fact that I started fresh with newly named layers, or if something else changed.
