Issue with attachments on offline areas - something to do with attachment keywords
314
07-05-2026 10:18 PM
gis_KIWI4
MVP Regular Contributor
Hi Team
Trying to use a fieldmaps form for related tables  (Pole -> Inspections)
The attachments are working when using the online area.
The offline area downloads fine but has issues opening the form.
2 Solutions
DougMorgenthaler
@gis_KIWI4 if you've included attachment elements in your form, you'll need to ensure that you've configured your offline options appropriately to work offline. Have you enabled the following option in the offline configuration in Field Maps Designer or the web map's offline settings?
gis_KIWI4
That worked like a charm!
Can't believe we glanced over that setting.
DougMorgenthaler
gis_KIWI4
