Issue with an Arcade calculation expression that works correctly in Map Viewer but not in Field Maps
2475
05-26-2024 06:06 AM
GuyNizry
I'm encountering an issue with a calculation expression that works correctly in Map Viewer but not in Field Maps. I have an expression that computes a fire incident number automatically based on the fire's status. When the fire status is 1 (new fire), the calculation finds the maximum number in the layer and adds one. When the fire status is 2 (continuing fire), the calculation finds the last fire number for the same user.
In Map Viewer, the calculation works perfectly. However, in Field Maps, I'm experiencing two issues:
For status 1, I get a number smaller than the maximum number.
For status 2, I get 0 instead of the expected number.
Here's the expression I'm using:
// Check if the edit type is 'INSERT'
if ($editcontext.editType == 'INSERT') {
    // Access the FeatureSet of the relevant layer with required fields
    var fs = FeatureSetByName($map, 'מדידת שריפה', ['FireEditStatus', 'FireGisID', 'created_user'], false);
    // Get the current user's username
    var username = GetUser($layer).username;
    // Initialize variables
    var MaxidStatus1 = 0;
    var MaxidStatus2 = 0;
    var hasStatus2 = false;
    // Iterate through the features in the FeatureSet
    for (var f in fs) {
        var fireEditStatus = f['FireEditStatus'];
        var fireGisID = Number(f['FireGisID']);
        // Check if the FireEditStatus is 1 and update the maximum FireGisID
        if (fireEditStatus == 1) {
            MaxidStatus1 = Max(MaxidStatus1, fireGisID);
        // Check if the FireEditStatus is 2 and the created_user matches the current user
        if (fireEditStatus == 2 && f['created_user'] == username) {
            hasStatus2 = true;
            MaxidStatus2 = Max(MaxidStatus2, fireGisID);
    // Determine the new FireGisID based on FireEditStatus
    if ($feature.FireEditStatus == 2) {
        // If FireEditStatus is 2, return the maximum FireGisID for the current user
        if (hasStatus2) {
            return MaxidStatus2;
        } else {
            return null;
    } else if ($feature.FireEditStatus == 1) {
        // Increment the maximum FireGisID by 1 for status 1
        return MaxidStatus1 + 1;
    } else {
        return null;
} else {
    // For other edit types, return the existing FireGisID
    return $feature.FireGisID;
Has anyone experienced similar issues with expressions in Field Maps, and what solutions might you suggest?
Thank you for your assistance!
Guy
RhettZufelt
MVP Notable Contributor
I approached it a bit differently, but this seem to be working as you expect in both map viewer and Field Maps app.
    // Get the current user's username from the FeatureSet
    var username = GetUser(FeatureSetByName($map, 'מדידת שריפה')).username
    var uservals = ''
    if (!IsEmpty(fs)){                                                      //make sure not empty dataset
        if ($feature.FireEditStatus == 2){
            var uservals = Filter(fs, `created_user = '${username}'`)      // If Continuing Fire, filter data by username
        }else{
            var uservals = fs                                             // else grab all data
        var numarray = []
        for (var n in uservals){
            Push(numarray, n.fireGisID)                      // push all matching IDs to array
        var newID = Max(numarray)                           // get the max ID number
            return newID                                   // If status = 2, return Max existing ID
        }else{
            return newID + 1                              // otherwise, return max ID incremented by 1
} else {
    return $feature.FireGisID;                         // For other edit types, return the existing FireGisID
R_
RhettZufelt
It appears as if Getuser has some issues with Field maps app and could be your issue.
Take a look here and see if this helps.  More here.
R_
GuyNizry
Thank you, @RhettZufelt , for the suggestion and the links.
I tried using GetUser as suggested in the post you linked, but the fire incident number still returns 0 in Field Maps instead of the maximum number for that user.
In Map Viewer, the correct number is returned. Do you have any additional ideas for solving this issue?
Here is the updated expression:
    // Get the current user's username from the portal
    var userInfo = GetUser(portal("https://www.arcgis.com"), "");
    var username = userInfo.userName;
    var MaxidForUser = 0;
    for (var f in fs) {
        // Check if the created_user matches the current user and update the maximum FireGisID for the user
        if (f['created_user'] == username) {
            MaxidForUser = Max(MaxidForUser, fireGisID);
        return MaxidForUser;
    } else {
        return null;
} else {
RhettZufelt
    var uservals = ''
        }else{
        var numarray = []
        }else{
} else {
R_
GuyNizry
Thank you so much for your help, @RhettZufelt. The approach you provided indeed resolves the issue, and the calculations are now working correctly in both Map Viewer and the Field Maps app.
I really appreciate your assistance in solving this problem. Your support has been invaluable.
Guy
