Is it possible to view relates in web map like you do in Field Maps mobile?
2210
6
04-20-2021 01:57 PM
elpinguino
I am building a landowner database and there are a few tables/forms I have related back to the property parcel. In Field Maps app, I like in the pop-up how you can see the list of relates right there and then go directly to the record.
Is there a feature like this in web map? I've had a look around, but not sure if I've missed it or if it's just not there. I can't find any answers when I try Googling either.
Or, does anyone know of a good work around for having the related record appear when users are at their desktop, go into web maps, click on a parcel and want to see all the related entries?
I've added a screenshot of the mobile version.Screenshot_20210421-085230_Field Maps.jpg
DougBrowning
MVP Esteemed Contributor
Nope it is not in the new one at all.  That makes it not ready for prime time in my opinion.  Not sure why relationships are always last - they are the first letter in RDBMS.  No there is not a way to have a button from Arcade.  You can do lookups and display data however using the FeatureSet functions.  They now work in Field Maps (but not Collector).  Take a look at this blog post for map diffs  https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/field-maps-and-map-viewer/
Chime in on this post where several of us are asking for it.  All I heard is "this year" but the roadmap said 2020 originally so not sure.  I sure hope so.
https://community.esri.com/t5/arcgis-experience-builder-blog/experience-builder-roadmap-in-2021-and-...
thanks
TravisSizemore
It should be right at the bottom of the pop-up in the web map.
You can also open the attribute table and scroll all the way to the right for your related record links.
elpinguino
Thanks for your reply Travis. I notice your screenshot looks like a Maps Viewer Classic pop-up. Do you know if it works in Maps Viewer? I'm sure there is a way to do it in Arcade... probably a sign I need to start learning it now, but if there was a quick way to enable it, that's what I'm after. I don't see that same kind of option in Maps Viewer.
DougBrowning
thanks
elpinguino
Just put a post in. Thanks Doug. Know of any good work arounds for now in Viewer... Can bandaid with Classic for now if I have to, but don't really want to.
DougBrowning
No there is no possible workaround.  Must use Classic.
DougBrowning
Nope we stuck with Classic for now for this reason as well.  There are a number of things missing in the new map viewer so not worth it at this time.  Experience Builder is also missing most things.  The plan was to move this year but it is looking like end of year now at least.
I just updated my post with more links to the differences.
