Is it possible to collaborate on a Field Maps Designer, or collaborate by adding to the "List of Values" in the Fields?
889
07-30-2024 11:06 AM
MarcosAntunez
I am currently an intern doing a summer project that I will not be able to complete in my remaining time at this organization. My knowledge of ArcGIS and its software is limited, but enough to accomplish what I need to do.
My issue: This project is to be continued by next year's interns. I created a feature layer through Field Maps Designer with two layers, Sites and Species. In the species layer, I have a combo box with a list of 60 species. It is likely that the future interns will have more species to document and thus will need to edit the list of species. When I shared this Feature Layer with a colleague, we were unable to find any way for them to add to the list of species. They were only able to add points to a map using the currently available list of species. I know of two ways I can add to this list: Entering Field Maps Designer and editing the list in the combo box OR accessing the layer in Content then Data, and editing the List of Values (Domain) in the fields tab. Is there any way to collaborate and allow future interns to edit the list of possible species?
DougBrowning
MVP Esteemed Contributor
Typically when we want multiple editors we need a Collaboration group. (funny it was one of your tags)  See here  https://doc.arcgis.com/en/arcgis-online/share-maps/share-content-with-collaboration-participants.htm
You could also change owners when you leave - well really you will need to do this anyway since your org will probably delete your account when you leave and thus also delete the data you own.
Note we do lots of species collection but our lists are 20,000 to 60,000 long so we use Survey123.  Better for long lists and no offline area stuff needed.
