Increase frequency of location tracks in Field Maps
3063
11
06-03-2024 02:36 PM
IngridHogle
Is there a way to increase the frequency/interval of location tracks while using location sharing in Field Maps? We are just starting to use Field Maps and are finding that the default settings for the tracks are too widely spaced for our needs. We are using Android Samsung Galaxy S9 Tablets, Field Maps 24.1.3 build 1493, and ArcGIS Enterprise 11.1. We're not sure what settings to adjust and would love some advice!
JakeBrownMaps
Hello @IngridHogle,
Field Maps does not have a configurable setting for frequency location points are collected.  As @GlenShepherd mentions we have some logic that factors the "activity" into account, that comes from the Android OS.  You can try turning off battery optimization within Field Maps, this is however at the cost of battery life, and depending on your needs may not be an option.  If you want to give it a shot - you can find that setting first by tapping the upper right "person" icon, then tap Location sharing & alerts, then toggling off Battery optimization.  This will make your location history breadcrumb more frequent and regular.
We do also have some configurable options available for MDM settings and app links that will help you configure location sharing.  https://doc.arcgis.com/en/field-maps/latest/prepare-maps/deploy-your-map.htm
You might also find this resource helpful for getting started. https://doc.arcgis.com/en/field-maps/android/use-maps/track.htm
Hope that helps-
-Jake Brown
Product Engineer Field Maps team
GlenShepherd
Hi @IngridHogle ,
What is the required interval you're after?
From what I can tell in the doco:
  • Last known location (LKL) is updated every 60 seconds by default
  • Distance intervals look to be fixed depending on speed of travel: "A minimum of 5 meters between points is required when walking, 30 meters when driving, and 10 meters for other activity types"
There is some mention that upload interval can be changed by editing the JSON of the web map using AGO Assistant: https://community.esri.com/t5/arcgis-online-questions/smallest-feasible-location-tracking-interval/t...
However this would be an unspported workflow - I'm not sure on the parameter that needs to be changed
IngridHogle
Good find, thank you! I'll take a peek in the map JSON. But I doubt any edits made here will help, since the interval we want to edit is within the tracks layer, which I believe is independent of the map JSON. We will try turning off battery optimization, as suggested in the documentation you found, and see if we get 1 meter intervals that way, as advertised is possible in the documentation. Thank you for all the suggestions and links!
JakeBrownMaps
Hello @IngridHogle,
Hope that helps-
-Jake Brown
IngridHogle
Hi @JakeBrownMaps
We followed all of these instructions and it helped for some users. But one user just returned from the field and showed me his My Tracks, which jumped him a little more than a tennis court away from his actual position multiple times. Tapping on some of his tracks, I see that Horizontal accuracy (RMS) is up to 51m for some of these stray Track Points. Can you help troubleshoot this?
The map he was using had the following App Settings preset in Field Maps Designer:
Collection
Accuracy: Distance 10m, 95% Confidence toggled off (can you explain the implications of this setting?)
GPS averaging: 5 points to average
Streaming: Distance 1 meter
His Field Maps Profile settings on his Samsung Galaxy tablet were as follows:
Collection settings
Accuracy 1m, 95% confidence toggled off (Note: I had requested staff to set this to 10m. The 1m setting was a mistake. I wonder if Field Maps just ignored this b/c it was unrealistic??)
GPS averaging toggled on
Streaming Distance 1 m
Location Provider
SX Blue II GPS [external GPS which gives up to submeter accuracy, connected via Bluetooth], Antenna height (m) 2.0
Battery optimization toggled off
JakeBrownMaps
Hello @IngridHogle - a couple things to clear up. With the current version of Field Maps, location sharing makes use of the integrated device location (not external GPS location provider)  and location sharing is also not bound to the collection settings accuracy requirements.  Perhaps capturing a line using streaming is a better fit for this use case?
In the future version of Field Maps - location sharing will use the active location provider whatever that may be, but again accuracy will not be bound to collection settings.
-Jake Brown
IngridHogle
Do you have a time estimate for release of the future version of Field Maps that will use the active location provider for location sharing tracks? That would be very helpful as we decide how to proceed.
JakeBrownMaps
@IngridHogle - time estimate is early 2025 for that version to be publicly available - subject to change.
We do currently have an invite only preview program we can include you in if you're interested.  Support for Android bluetooth location providers should be included in the "tech preview 3" slated to be available in the first week of July.   Please  email arcgisfieldmaps@esri.com if you want to get the ball rolling on that.
-Jake
IngridHogle
Thanks again for all of your help on this, @JakeBrownMaps !
  • Do you know if the recent November 2024 release of Field Maps 24.3.0 includes support for Bluetooth location providers, as mentioned in your last response, so that this higher accuracy GPS data can used for location tracking "breadcrumbs"?
  • Would support for location tracking based on higher accuracy external GPS via Bluetooth apply to both Android and iOS?
JakeBrownMaps
@IngridHogle  -  apologies for late reply.  The version of Field Maps that can use external GPS provider for location sharing (iOS and Android) will be released in 2025 (no date set yet), however we do have a Early Adopter Program you can sign up for an preview the release - just send email to arcgisfieldmaps@esri.com and request access to join.
