Incorrect current location on Field Maps
956
07-24-2024 10:26 PM
ErinSwainsona
So I have built a form for Field Maps, and I can place a point and the form is correct. But the current location that it is giving me is incorrect. It is currently saying I'm in Poland instead of Australia. Have I put in the wrong coordinate system somewhere or missed a step before I use the layers in Field Map? On the map in my online portal I added a bookmark to the location that I wish to be in but this hasn't had any affect either. There are no points on the map as the aim is to create new points and go from there.
Tags (3)
RobertBorchert
Honored Contributor
what projection are you using? Personally  I would recommend WGS 1984 Web Mercator (auxiliary sphere)
Are you using a mobile device or a computer when you observe the incorrect location.
