How to show the attached photos in the pop up instead of the attached tab?
1239
09-13-2022 10:00 PM
BrandonGuo
I configured the web map to show attachments as a gallery. However, in the Filed Maps app, it's not showing in the pop-up. Is there any way to show photo attachments after the user selects an item instead of going to the attached tab? Thank you.
ChrisDunn1
Hi @BrandonGuo - the current release of Field Maps does not support Popup Elements - the newer fully-featured popups created by the Map Viewer. This includes the new options for displaying Attachments as a list or a gallery within their own element in the popup instead of in a separate tab. That support is coming in the 22.4 release this fall. However, if you'd like to try it out early Popup Elements are supported in the current Beta, you can find out more here: https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/arcgis-field-maps-early-access-r....
ChrisDunn1
BrandonGuo
Thank you so much.
