How to make a field editable or calculated depending on a condition in Arcade?
777
10-29-2024 12:50 PM
JamesPoeschel
I have a field I need to be set to 0 if another field is equal to 0, otherwise, I'd like the field to be editable and show its normal drop down. Is this possible?
if ($feature.Transit_BusStopLocation == 0) {
  return 0
// else show drop down
ChristopherCounsell
MVP Frequent Contributor
No, editable questions won't allow calculations in Forms.
https://doc.arcgis.com/en/field-maps/latest/prepare-maps/configure-the-form.htm#ESRI_SECTION2_5F65DF...
Survey123 allows for this.
You could:
  • Add an extra field to allow for manual entry
  • Always calculate the exisiting field and add logic have it point to the manual entry or apply the desired calculation
ChristopherCounsell
You could:
