I am unable to use a field which has the same "Description" of Coded Value Domains in ArcGIS Filed Maps Designer. Does anyone know that this behavior known limitation?
I am unable to use my existing data, so confused...
Steps:
Thank you in any advices,
hitsujir_dev
Hi @hitsujir_dev ,
I think this behavior is older than November 2024 since the community has related posts of the same issue by 2022. Please look at the post below for an explanation of the issue and a possible workaround.
https://community.esri.com/t5/arcgis-online-questions/duplicate-labels-in-a-domain/td-p/1190056
Hi @hitsujir_dev ,
Thank you for your reply. I checked the old posts in 2022!
It's not good to use the same "Description" certainly, so I will change my existing data.
Regards,
Rina
