Form placement can it be docked on right side of screen in app?
1309
04-26-2021 03:21 PM
kmsmikrud
Are there options to change the default form placement on the map within Field Maps? Currently when a user clicks to 'Add' a point on the map, the data collection form goes to the left or bottom of the screen depending on how the user rotates the iPad in our case. Is it possible to change the form to be on the right from versus left-side? A user says this would make their use of the app much more efficient since they are right-handed and using a stylus for data entry.
I haven't found any options or ways to change this.
Thanks in advance,
Kathy
DougMorgenthaler
@kmsmikrud I'd recommend suggesting this as a new idea to allow others who might have the same interest to view and contribute their thoughts.
DougMorgenthaler
kmsmikrud
Thanks @DougMorgenthaler ,
Based on your response, it sounds like it isn't currently possible to dock the menu on the right. I will add it as a new idea. Thank-you,
Kathy
SarahJorgensen
@kmsmikrudI wonder have you had any luck with this? Has this been updated to enable changing the default location of form in the Field Maps app? I use an iPad also and until the recent update 25.2.2, the form appeared at the bottom of the screen with the option to maximise/minimise as required when in portrait view. Now it has moved to the left hand side in both portrait and landscape view and this really interferes with my data collection. Its very frustrating. There should be an option available to choose where you would like your collection form to appear on the screen.
