Fieldmaps app on Iphone/Ipad asks for client certificate when opening webmap
1744
10-20-2021 03:26 AM
NielsB
When loading a webmap in Esri Fieldmaps app on Iphone it asks for a client certificate while if I open the same webmap on a android device (in fieldmaps) it will open the map correctly.
How do I create a client certificate for fieldmaps?
Thanks in advance,
Niels
by Anonymous User
Not applicable
If you are using ArcGIS Enterprise, there was a similar issue reported on Android a couple weeks ago  It turned out to be an issue with the Let's Encrypt root certificate expiring. A solution for Android was posted there and perhaps you need to do something similar for iOS.
