fieldmap template builder not available for related table
1837
06-08-2023 02:47 AM
tendtreesTC
Hi there,
Can anyone tell me why I can't use the template section in the field map app builder for related tables?
my related table is an audit and I would like to have a number of defaults for different fields.
The survey was originally built in survey123 and I am now migrating it to be used in fieldmaps.
any help would be much appreciated
AntonioPatera
Same problem. So far nobody has replied. Neither Esri support. Another bug...
Tiff
I have a Field Maps map for two layers and two related tables, and I am able to use the Templates section. Are you able to configure the form for the table, just not the templates? Is it grayed out or not showing up?
AntonioPatera
I can configure le form, but the template does not show up. Anyway, everything worked fine for the other two dozen of projects.
