Field Maps UpdateFeature URL Parameter
10460
10
11-02-2021 09:22 AM
nspittlemeister_LCFPD
I am trying to open and edit in Field Maps from a Web AppBuilder application and running in some difficulties with the UpdateFeature URL parameter and the GlobalID. In the web application source web map I am using the following URL parameter in the custom attribute popup for a feature service:
https://fieldmaps.arcgis.app/?referenceContext=updateFeature&itemID=15bf4c9d6ceb42cb9d1f532c7ec8c6de...
When it opens in Field Maps, it opens the correct map, but does not open the feature to edit it. In closer inspection of the link that is generated in the web map, it seems to be adding extra characters (in bold below) before and after the GlobalID in the URL:
https://fieldmaps.arcgis.app/?referenceContext=updateFeature&itemID=15bf4c9d6ceb42cb9d1f532c7ec8c6de...%7B85788B3A-4339-43CF-B137-1B11E200A1B2%7D
The GlobalID should just be shown as in the URL as: 85788B3A-4339-43CF-B137-1B11E200A1B2
As anyone seen this before and know how to fix this or have a workaround for this type of URL parameter?
Thank you for the help!
Nick
ColinLawrence
Sorry for the delay in getting back. Yes I was thinking of something similar using arcade so I am glad you arrived at that. It is something the team is researching how to better handle in the future (brackets vs no brackets). Thanks!
Colin
Regards,
Colin
