Field Maps syncronize but not update collected data in the layer
889
03-12-2024 10:16 AM
Fabio_Pires
I successfully perform the synchronization in offline areas in Field Maps, however, the collected data does not appear in the layer.
Using the database IDE, I can verify that the data is in the table but for some reason it does not appear in ArcGIS Pro or Enterprise.
Has anyone been through this and managed to solve the problem?
By the way, I'm using Branch version and replicas.
AlamFloraSdnBhd
Hi, I also have the same issues. The field map showing the points was updated, but when I checked into the Database Enterprise, the attribute record of the points spatial is NULL.
I also designed the Dashboard to monitor the database summary, but the dashboard did not update the record.
I hope ESRI Tech can help us to find the solution.
