Field Maps on IOS does not load the Annotations of the Layers
1848
04-13-2022 04:22 AM
AngelRomoSandoval
Hello, I have the following bug.
Using the same online map, in Android I see the layers with annotations but in an Ipad (IOS), no.
Kind Regards,
DavidForbuss1
Do you have the labels set to show up at a certain zoom level?  Because the iOS is a tablet, you might have to zoom in closer to see them.
AngelRomoSandoval
Thanks for your support @DavidForbuss1 , but yes, I the layers are setup to show up at a certain zoom level, but even zooming out and in, nothing appears.
DavidForbuss1
Hmm that's frustrating.  One thing you could try is building a brand new map and re-adding the datasets to it.  Maybe even try it in the beta MapViewer.  I had some trouble in earlier versions of iOS showing labels that had halos on them, so I had to turn the halo effects off.  What version of iOS are you using?
AngelRomoSandoval
Yes, a little bit frustrating, thank you for your hints,
Sadly, I cannot create a new map, I have a enormous amount of formulas and calculations in the already created map (online featureclases), I would need to copy-paste everything in the new map.
By the way, I am using: IOS Version: 15.1
*But I know that the field workers have another versions, I should test in their devices.
