Field maps Form for editing features
1074
05-05-2021 03:12 AM
Sietse_de_Haan
Hi there,
I have a question about the field maps app. Is it true that the form will only be used for collecting new points/lines/polygons? Or should it also work for editing excisting features?
My form also dissappears every time I close the Field Maps app in AGOL. I always save the form and the pop up of it being saved also shows. Is it bugged?
I am using Field Maps version 21.1.1
Sietse de Haan
https://www.linkedin.com/in/sietse-h-de-haan/
by Anonymous User
Not applicable
The form works for creating new features as well as editing existing features.
We are not aware of any bugs related to saving a form. Each form is saved into the webmap. Make sure you aren't modifying the map in both Field Maps web and in Map Viewer at the same time. If you have both apps open at the same time, after you make a change in one, you need to refresh the other app.
