Field Maps error 'Unable to submit 1 or more attributes failed'. When submitting to related table
5315
12
05-07-2024 05:36 AM
RobynSnookCCB
I have a hydrant inspection feature layer with 5 related tables hosted on ArcGIS Online. One of the tables is giving the error in the title. All relationship classes are setup as shown in the picture but this is the only one giving an error. Any ideas what this would be?
KerriRasmussen
Hi @RobynSnookCCB . When you try to submit the form for that specific table, are there any fields highlighted showing which field is causing the error? Or do you happen to be using an Arcade expression on any of those fields? If so, it's possible there is something wrong with the expression were it can't run properly.
RobynSnookCCB
No field gets highlighted, there was some arcade as a calculation and title in the form and pop-up, even after removing it, it still won't submit. I have arcade with the other tables to which are working fine. Thanks though.
I republished as another feature service and it works fine but I'm hoping to fix the original so I don't have to re-do a lot of work.
KerriRasmussen
@RobynSnookCCB in the original feature service, try removing the Arcade from the form (if you haven't already) and save the form to the map. Then Field Maps mobile app, on the browse screen (the screen with the list of all your maps) pull the screen down to refresh, find your map and if it's listed as the current map, use the overflow menu (...) to select Reload Map, if it's not the current map, you can just open the map. See if you are still having issues submitting data.
RobynSnookCCB
No it did not work
KerriRasmussen
Ok, thank you for trying. If you are interested in doing some more troubleshooting on the original feature service, I would recommend reaching out to Esri Technical Support. Your other option, as you already stated is to update your maps with the new feature service that you created that isn't showing the error.
OMadarang
Hi @RobynSnookCCB,
I encountered the same error when trying to collect field data using Field Maps.
What I did is checked the feature layer fields in the form and noticed that from one of the field under Logic, below the Editable check box is a message "Editing is disabled in the field settings".   I checked the details of that field and changed the Editable section to Yes. I then return to the Field Map designer form and after refreshing, the message is gone and  click the Editable check box under the Logic section . When I tried to collect field data again, there is no more error.
AraceliLopezAcosta
This worked for me, must be sure that the option "Allow attribute editing" is enabled on the field. I had recreate my fields, and it worked.
DebSF
@RobynSnookCCB Did you ever figure this out? I'm having a very similar issue, except sometimes it does submit and sometimes it fails, even with the simplest 1-field form.
DaveAlmond
I am experiencing the same issue. Hosted feature service point layer with 1:M relationship class with a table layer in the same hosted service. The table in the ArcGIS Online item's Data tab indicates that there are records (which would be my tests) but the table is blank shown below. maintlog.pngmaintlog.png
