Field Maps Designer New Layers
1567
04-06-2023 08:51 AM
MichaelLohr
Thanks @SarahSaint-Ruth , for the info provided at the below location. A follow up question below.
https://community.esri.com/t5/arcgis-field-maps-blog/what-s-new-in-arcgis-field-maps-november-2022/b...
You mention in your response that, paraphrasing, in Field Maps Designer (FMD) you can 'create new layers for the field'. Do you mean that a new data layer for an online map can be created completely in FMD without first creating a new shapefile or geodatabase with schema and attributes created by traditional desktop ArcGIS or ArcPro followed by publishing to a feature service?
I will watch the webinar and other documentation you linked to previously and this may be answered there, but my first thought before going there was my above question.
Thanks again.
SarahSaint-Ruth
Yes, you can create a layer in Field Maps Designer. Here is a video showcasing how to do this. You can also view in our webinar I linked to in the previous post.
SarahSaint-Ruth
MichaelLohr
Thank you for that information, Sarah. I have tried it and it does in fact work as you mentioned.
For those of us who are more used to the traditional data creation scheme in ArcMap/ArcPro and data storage on an internal ArcGIS Server, this is a little outside of that methodology. Creating a data layer in Field Maps Designer results in a 'hosted' data layer stored on the ESRI AGOL Servers. As such, that layer is not available, I don't think, to the desktop users not on AGOL. The hosted data layer can be exported to a stand alone shapefile via the AGOL interface and made available in the traditional way to desktop users. But if you had a dynamic dataset being updated by AGOL data collection, you would be challenged in keeping sync'ed up with that with a series of Exports to a traditional shapefile.
Thanks again for your guidance, Sarah.
