Field Maps Designer > Offline toggles off by itself - When? Why?
444
10-29-2024 02:23 AM
elpinguino
Hello, I've started to pick up using Field Maps more frequently again. I noticed in the Field Maps Designer > Offline tab the Offline toggle is sometimes turned off. I'm not sure why. I'm the only one that goes in there.
I understand this may happen sometimes if a new layer gets added in, but are there any other times to be aware of this happening? Is there a list of these somewhere in the documentation? Does anyone else experience this?
We haven't run into any major issues yet, but it's happened more then once now that I'll go into Field Maps Designer and noticed Offline is toggled off. Or is it anytime a change gets made to the map even if it is in Map Viewer, not Field Maps Designer?
I will also be onboarding someone else to help me with this who has less experience with Designer and would like to share these with them.
